Mrs Buster Posted February 17, 2018 Posted February 17, 2018 So Buster and I went shopping in my roadster and both opened the windows. Now they won’t go back up. Any ideas please as Bob is stumped. He has changed the switches as he had spare one lying around as you do. Tried thumping the door as per advice from other forums but that’s didn’t work either. Didn’t get the shopping done either so I have a hangry man. Help 1 Quote
RDON Posted February 17, 2018 Posted February 17, 2018 possibly need new motors by the sounds of things! i guess buster tried the window reset procedure too? Quote
buster Posted February 17, 2018 Posted February 17, 2018 did indeed but to no avail,then the drivers one work again but still no joy from the passenger side.. Quote
buster Posted February 18, 2018 Posted February 18, 2018 just what i thought but there no fuse for the windows from what i understand.....strange i know......well looks like its a motor on the n/s. thankfully the o/s one came back to like...was odd though both stopped working. Quote
Ebized Posted February 18, 2018 Posted February 18, 2018 Found, what has turned out to be a very useful guide for window motor problems, in case you might need it Bob: Quote
buster Posted February 18, 2018 Posted February 18, 2018 cheers mate,tried all this but the motor only seems to run in the down position ....hope a new motor work correctly Quote
ZMANALEX Posted February 18, 2018 Posted February 18, 2018 Hate to state the obvious mate, but you haven't accidentally knocked the window lock switch? Quote
buster Posted February 19, 2018 Posted February 19, 2018 stripped and cleaned the old motor with fingers cross but i still only operated in the close rotation...oh well new motor should be here Wednesday Quote
buster Posted February 21, 2018 Posted February 21, 2018 so learnt the hard way tonight.....new motor arrives fitted and still no luck......think i ve found the fault in the wiring loom plug on the "a" post where it clips to main part of the zed...will check the weekend. Quote
