blindbandit Posted December 28, 2016 Posted December 28, 2016 My zeds getting high in the miles and I the next 10,000 will be the hardest yet as it's getting tracked and drifted. It's had a good service history and I've just replaced diff, gear box and engine oil and filters. My question is to you guys that know this engine well, what engine components should I look at replacing/upgrading or maintenance should I carry out to stave off bhp loss. Any top tips much appreciated Sent from my iPhone using Tapatalk Quote
-Bradders- Posted December 28, 2016 Posted December 28, 2016 (edited) No help but mine went bang at 135k lol Edited December 28, 2016 by -Bradders- Quote
Jetpilot Posted December 28, 2016 Posted December 28, 2016 Not much you can do except use a decent quality oil and keep a check on the level and follow the service schedule. Quote
Mopedmark Posted December 28, 2016 Posted December 28, 2016 Sounds like your doing the right stuff, timing chain is biggy, 1 Quote
Ekona Posted December 28, 2016 Posted December 28, 2016 Timing chain, water pump would be what I'd be doing engine wise. 1 Quote
blindbandit Posted December 30, 2016 Author Posted December 30, 2016 Cheers for your replies, I'll check through the service history to check when timing belt was changed, and I've been after a compression tester for a while so it's a good excuse. Sent from my iPhone using Tapatalk Quote
ZMANALEX Posted December 30, 2016 Posted December 30, 2016 Do not waste your time or money on compression tests or timing chain chain replacement. The best preventative measures in this instance is to use a good quality engine oil and service regularly, together with very regular dip stick checks on the engine oil level. At 135k miles there is bound to be wear and tear present, so chains and low compression issues should only be dealt with as and when they happen, which might be never. However, if the engine eventually does go pop, then just drop in a known pre-owned engine from a known and reputable seller. Quote
ZMANALEX Posted December 31, 2016 Posted December 31, 2016 I think that you may find that the OP is looking for preventative options to actually avoid an expensive engine build. Quote
