F100Jay
2-piece Discs
Because they're cheaper, usually. The PF stuff is absolutely top notch, and you do pay the premium but nothing I've ever used has come close. They worked exceptionally well on my Roadster, which has the extra weight over and above the coupe, on every track I pushed hard on.
Share this post
Link to post
I will hold you on this one :)
Will go for this set up later on
Sent from my SM-G850F using Tapatalk
Share this post
Link to post
Ebc dont tend to work well on heavy cars, dont ask me why.
I have just switched from years of ds2500 which i thought were a great pad to Carbon Lorraine Rc5+ pads and they are another level, bite is impressive and zero fade even on heavy track use.
  • Like 2
Share this post
Link to post
I'd also consider the RC5+ as well, another great compound.
Also, if you're going this far, then I'd recommend getting the Endless brake fluid as well. Pricey, but it's the same stuff used in very top level motorsport (Honda used to use it before they were Brawn, and possibly during Brawn as well I suspect) and is pretty much the ultimate stuff out there.
Share this post
Link to post
What discs do you use with CL's as they don't make their own discs are far as I'm aware?
Tom
Share this post
Link to post
I will contact you prior sourcing and ordering stuff. Since winter is coming i won't be upgrading b4 spring. I know this combo will be pricey as well but again a lot cheeper than BBK
Share this post
Link to post
Tom
I didnt use them on the 350, but i know Docwra swears by them, i would be happy using any decent aftermarket disc with them however.
Share this post
Link to post
I've been using Performce Friction Discs and Carbon Lorraine Rc6 pads on my TT Z.
Braking is fantastic. I'm just about to try DBA 5000 discs as the PF have finally died after lots of track time.
Share this post
Link to post
Would it not be significantly cheaper just to replace the PF rotors, given that's a huge benefit of running two-piece discs? Or do you just fancy a change?
Share this post
Link to post
I've never put much stock in ebc. Pads for performance car i always go either performance friction or carbotec xp8 or 10. They can be dusty and a little sqeally at times. But bite and braking are excellent.
Share this post
Link to post
Loading...
350z-uk.com
370z-uk.com
