Has anyone else experienced a sound from underneath the car (hard to pinpoint a direction) that sounds almost like a click when you brake and put a bit more pressure on just before you come to a standstill. It only clicks once just before the car stops moving and doesnt happen at all during normal driving.
Sounds like clicky axle
Don't panic
It's a case of a bit of lube around the splines
Do i need to take apart the entire rear assembly to get to sort this?
Just noticed this is in the 370z section, do you have a 370 that is clicking? Wasn't aware the problem carried through from the 350z? So maybe it is something else?
yeah my 370 is doing a single click just before the car stops moving.
