Hi Guys,
Been having trouble with my key fob. Can no longer lock and unlock the car. There is a fresh battery in the key fob so I know it's not that. I'm assuming there is a fuse for the Central Locking and would like to check it. Trouble is, I don't know where the fuse is located. I know there is a fuse box in driver side footwell and also where the car battery is, but to save me having to check both, can someone point me in the right direction? It might not be the fuse, but if nothing else, it would cancel that out as the issue.
Thanks.
Could need just reprogrammed again. Happened to me after the bodyshop had it for a couple months with the battery disconnected.
Should be a how to on the forum somewhere.
Posted (edited)
Justgivemethedamnmanual.com
It'll be in there somewhere.
Posting from phone so it's not as easy to find.
Maybe Admin could sticky this for the link, I found it by accident.
Edited by Quinster
Thanks for the link Ebized. Just tried that programming routine and it worked a treat. My key fob is now working again.
Just curious though, what causes the key to suddenly lose its programming?
