LiamR Posted October 8, 2015 Posted October 8, 2015 So the zed failed its mot this week on a snapped front suspension spring, the problem is neither me or the garage know what the spring is to get a replacement (will be doing both fronts anyway). Bought the zed years ago, still running on the same lowered springs when I bought it and it is very low. The only information I have is I'm pretty sure they were apex springs and the part number for the shock absorber is 56110 cd700. I really hope someone can help, if nothing else I just need to know what the actual drop is on the spring, I'm sure its 30mm but dont want to just guess. Thanks in advance everyone Quote
MITZ@CougarStore Posted October 8, 2015 Posted October 8, 2015 Apex Springs are usually yellow... Quote
LiamR Posted October 8, 2015 Author Posted October 8, 2015 I just called you guys at cs, I think someone is calling me back once back from a road test :-) Quote
ZMANALEX Posted October 8, 2015 Posted October 8, 2015 Best to replace both front springs or all four. Eibach with a 25mm drop would be a plan, depending on what you have on the rear at the moment. Alex. Quote
LiamR Posted October 8, 2015 Author Posted October 8, 2015 was thinking of replacing all 4 to be honest. What would you suggestions be bearing in mind they are original shocks all round and 20" alloys? Quote
ZMANALEX Posted October 8, 2015 Posted October 8, 2015 Eibach will give a 25mm drop all round so the "gap" will depend on what wheels and tyres you have and if you have spacers fitted. Tein are also decent but not such an aggressive drop. All depends on what stance etc. you are looking for. The above springs are fine on OEM shocks. If you prefer an adjustable set up, then you will have to look at coil overs. Alex. Quote
ZMANALEX Posted October 8, 2015 Posted October 8, 2015 pm'd you Alex Received and replied to, Alex. Quote
LiamR Posted October 8, 2015 Author Posted October 8, 2015 Issue resolved, thanks for the advice guys- just ordered a set of Teins from Clarke Motorsport, great service massive thumbs up :-D Quote
M1 6RYF Posted October 8, 2015 Posted October 8, 2015 I have just bought a set of apex springs and put them on a few weeks ago. They were a drop of 30mm. So teins should leave you with plenty of room Quote
