Rs2oo Posted September 23, 2015 Posted September 23, 2015 Hi all. When cold, even on a nice day I struggle to get the car into gear until t's warmed up. Then,2nd gear never engages smoothly, it doesn't crunch, it just doesn't like going in and fights me and sometimes it feels like something is knocking. If I am careful and slow with the change into 2nd either up or down, its not bad. Gearbox oil never changed 46,000 miles. Will an oil change fix this or is it a syncro problem ? Which gearbox oil is best please ? Thanks - Martin Quote
KyleR Posted September 23, 2015 Posted September 23, 2015 Certainly try a gearbox oil change first with an added tube of molyslip. Just get Nissan gearbox oil from a trader on here like Clark Motorsport or Cougar Store 1 Quote
Cookie Posted September 23, 2015 Posted September 23, 2015 Genuine Nissan oil and a tube of molyslip helped with mine. 1 Quote
Ebized Posted September 23, 2015 Posted September 23, 2015 Seen hundreds of posts like this during my time on the forum and going back to when 350's were still quite new. The boxes are strong but best described as "agricultural" ......and that's what helps to make it such a great driver's car. I was spoilt with the 370 and the synchro-rev that made changes, both up and down, a breeze! But a common characteristic of the 350s while warming up. But if it continues when fully warmed up then that might need further investigation. No harm doing an oil change + molyslip that has certainly improved things for many. During my time with the 350s (and 370 for that matter) always made a point of doing what might be best described as a two stage shift while warming up - i.e. 'feel' it through neutral rather than one solid pull through as you would/can when fully warmed up 2 Quote
allaboutthepasty Posted September 23, 2015 Posted September 23, 2015 Genuine oil and Molyslip didn't really help mine. Just learned how to get it into 2nd when cold. Quote
davey_83 Posted September 23, 2015 Posted September 23, 2015 ive found going from 1st to neutral and then to 2nd when cold is fine. once the gearbox oil is warm, shifting directly is fine. my last car * fwd had a B&M quick shifter, so this is what im use to. 1 Quote
