Roscoe Posted September 10, 2015 Posted September 10, 2015 Afternoon, after some advice. I'm looking into doing a battery recondition charge on my original 2008 battery as it's showing signs of age. To do this I will be disconnecting the battery from the car for about 24-36 hours (estimated time to complete cycle) Will I run into any issues with the alarm, or any other systems on the car having it disconnected for this amount of time? Thanks in advance Quote
Tricky-Ricky Posted September 10, 2015 Posted September 10, 2015 Personally I would be replacing a 7 year old battery, what do you mean by recondition charge, if its not holding a charge then it needs changing, if its already playing up you can bet money you will be replacing it as soon as the cold weather arrives, You shouldn't have any issues with the alarm or anything else. Quote
Tricky-Ricky Posted September 10, 2015 Posted September 10, 2015 Doe's the std Z have a coded radio then? never seen one with std LOL! Quote
Juggalo Posted September 10, 2015 Posted September 10, 2015 You doing the old epsom salts trick? As for the car, there shouldn't be a problem. Radio will likely lose it's settings. Quote
Shenley Posted September 10, 2015 Posted September 10, 2015 A new OEM one from Nissan costs £59 all in. A charger thingy costs more, and will it work on your battery?? Quote
Roscoe Posted September 10, 2015 Author Posted September 10, 2015 I have the charger already from a family member. Thought it was worth a try as it's not costing me anything to potentially get the battery through this winter. Quote
simonlap Posted September 10, 2015 Posted September 10, 2015 Deffo go for a new battery. I have gone down the route of trying to keep an ageing old friend going on and on and on. The worst possible time you can imagine, it will let you down. Quote
Tricky-Ricky Posted September 10, 2015 Posted September 10, 2015 As I said if the battery is already giving trouble IE not holding a charge, the first hard frost will see you stranded with a dead battery. Quote
Roscoe Posted September 10, 2015 Author Posted September 10, 2015 Ok thanks guys will look into getting a battery before the winter sets in! Cheers Quote
