Joeycuz Posted July 8, 2015 Posted July 8, 2015 Hi guys, I fitted a set of Eibach pro lowering springs Sunday and all looked Fine. However I've noticed that the rear N/S seems to be sitting slightly higher than the O/S. Theres about 5mm difference. Could this just be them settling down or could I have a fitment issue? Cheers Quote
BulletMagnet Posted July 8, 2015 Posted July 8, 2015 Somebody may correct me, but check that the spring seats are the right side up Quote
Keyser Posted July 8, 2015 Posted July 8, 2015 Somebody may correct me, but check that the spring seats are the right way up Corrected that for you As BM said check all mountings and check the drop links - they may be jamming if they are old and not the adjustable type, had an issue on Busters when we did his ARB's with lowering springs the pre load is very high when you lower the car. 1 Quote
Jp606 Posted July 11, 2015 Posted July 11, 2015 Mine was like this, I think it just settled over time or the fuel tank sat more to one side or something can't remember. Quote
buster Posted July 12, 2015 Posted July 12, 2015 Somebody may correct me, but check that the spring seats are the right way up Corrected that for you As BM said check all mountings and check the drop links - they may be jamming if they are old and not the adjustable type, had an issue on Busters when we did his ARB's with lowering springs the pre load is very high when you lower the car. now rectified with adjustablr drop links. Quote
