M350ZB Posted November 25, 2007 Posted November 25, 2007 Hi all, long time no see or hear for a few,  Driving my Z last night, first time in about a week, been so busy, and the srs (air bag warning) light came on and is flashing, i done a search on here last night and found out about hte ecu reset, tried this but it does not even clear it, also fiddled away with the cables underneath both seats, also found out on here, and nothing, only other thing i can think of is fuse's, going to check this out today, but if not think its a trip to the stealers.  Has anyone resolved this problem there self, or is it a 100% a strealers job, and any ideas on prices, e.t.c  Its a f>*&k*ng shame as was going to pop down bluewater tonight, why me, last week had two nails in both left side tyres on my mg zr at work, god leave me alone, lol  Any help guys i would be much greatfull  Thanks All Quote
Zedrush Posted November 25, 2007 Posted November 25, 2007 Hi mate, hmm, SRS light can mean the following:  Letting battery drain too low Bad Sensor Blown fuse Unplugging the car’s battery Removing the gauge cluster/installing aftermarket gauges Bad clockspring (located inside your steering wheel) Bad ECU Bad reverse light switch on transmission Airbag defective/unplugged  Hopefully its not a bad ecu, and probably low battery, do a test and get yourself down to halfords if defective.when you drive do you notice anything different? Powerchange or fluency in the power delivery? If not then It probably aint too serious and Id get yourself down to the bluewater meet Quote
WoREoD Posted November 25, 2007 Posted November 25, 2007 Mine came on recently but dissapeared after a dealer reset. I'm fairly certain it was caused by non-retracted passenger seat belt locked out but not in the receptacle..... (somebody will probably tell me now I'm talking out of my a*se!). Â JohnK Quote
Zedrush Posted November 25, 2007 Posted November 25, 2007 probably nothing serious then, id get yourself down too bluewater and stop making excuses... Quote
M350ZB Posted November 25, 2007 Author Posted November 25, 2007 gonna have a look at the fuses some point today, not to sure when it came on, just looked down and noticed it, and no no differences in driving or nothing at all, drives like a dream still !, like i said done the ecu reset, and no joy, played about with the wires under neath the seats and still no joy, so thinking i will check the fuses today ? Â If not to the stealers it is tommorow ! Quote
Zedrush Posted November 25, 2007 Posted November 25, 2007 gonna have a look at the fuses some point today, not to sure when it came on, just looked down and noticed it, and no no differences in driving or nothing at all, drives like a dream still !, like i said done the ecu reset, and no joy, played about with the wires under neath the seats and still no joy, so thinking i will check the fuses today ? If not to the stealers it is tommorow !  If no power difference and you done an ecu reset, then id go with the battery. You coming to the meet now? Quote
bronzee Posted November 25, 2007 Posted November 25, 2007 One of my 350 mates here in NZ had one of his replaced. If it's the same thing, it's a rubbing wire in the seat airbag. It's also a known problem, as per the dealer he took his Zed too. Â His was replaced by the dealer at Nissan's expense even though his car is a 2003 and well out of warranty. Quote
M350ZB Posted November 25, 2007 Author Posted November 25, 2007 Right after a little think e.t.c, i decided to check the fuse's in the drivers foot-well, i took the srs fuse out, and it seemed ok, i then put it back in started her up and it started flashign again, then i though ok so i swapped this fuse for the one next door to it, both being 10AMPs, then strated her up and it went out, only had her running for about 3 minutes, so only time will tell tommorow when i have another look, will replace as what seems a faulty fuse, ill up-dat you more tommorow, thanks all for your help and ideas Quote
GIXXERUK Posted November 26, 2007 Posted November 26, 2007 glad youre sorted (touch wood) strange one that ! did the contacts on the fuse look at all dirty ? Quote
Andy Posted November 26, 2007 Posted November 26, 2007 Bizarre!! Glad it seems to have sorted itself out though. Hope you can make the next meet mate. Quote
M350ZB Posted November 26, 2007 Author Posted November 26, 2007 Touch Wood all cured, may be a bit of dirt on the connection, who knows, just swapped the fuses around, both being 10AMPS and woo hoo, its all good, drove around for about ten miles, no problems....... Â Saved me self some dollar for once, love it ! Quote
AFCSMUDGE Posted February 22, 2008 Posted February 22, 2008 Hey there, my airbag light has just started flashing, i've read your thread and wondered how you were resetting the ECU & if you have any other nifty tricks to try before involving Nissan? Â Cheers Quote
M13KYF Posted February 22, 2008 Posted February 22, 2008 if you check the guides section, the ECU reset is there Quote
stuey Posted February 22, 2008 Posted February 22, 2008 if you check the guides section, the ECU reset is there   it is there.........  and it duz work........... unless there is a problem  you will find the light will come on again after 10 mins driving if parts need replacing....... Quote
AFCSMUDGE Posted February 22, 2008 Posted February 22, 2008 Excellent Thanks for your help..wonder how many tries i'l need before getting it right :-) Quote
stuey Posted February 22, 2008 Posted February 22, 2008 Excellent Thanks for your help..wonder how many tries i'l need before getting it right :-) Â its not that hard.................. dippy.............!!! Quote
