Compression Test Results
evest
Hi folks,
Just about to change my rocker covers so took the opportunity to do a compression test. Car is a 2004 GT with approx 130K on the clock, road driving only, not been tracked or otherwise abused. I did the test twice just to er.. do it twice...
Run 1 Run 2
Cylinder 1 171 180
Cylinder 2 182 184
Cylinder 3 190 188
Cylinder 4 190 190
Cylinder 5 172 174
Cylinder 6 178 191
All seem roughly within 10% of each other. Interestingly, cylinder 5 is down a bit... Cylinder 5 is why I'm changing the rocker covers, as I had oil in the spark plug aperture, which I was told would be a leaky seal on that rocker cover. Could there be another issue - the compression doesn't seem to be significantly worse than the others. (I did a wet test on cylinder 5 and compression went up to 220 - piston rings? Will wet test the others tomorrow)
Cheers :)
The fact that the two tests show pretty different figures is a bit odd, especially cylinder 6, how did you conduct the test? normal procedure would be to use a fully charged battery, in the case of the Z pull the fuel pump or injector fuse, wedge the throttle fully open and remove all plugs, and make sure you turn the motor over at least 6 times for all cylinders.
The fact that cylinder 5 went from 174 to 220 with oil (how much did you use?) is rather worrying, the figures themselves are not bad for a cold engine and the mileage, I usually run a hot and cold test to see how much change there is.
That's not bad going for a cold compression test. Tbh you should expect an improvement on compression with the wet test as a130k engine will have expected ring wear. Because you are within 10% that's fine. A hot compression test is better as expansion is accounted for and representative of true ring leak.
Reassemble that baby and keep motoringðŸ‘
Procedure was pretty much as you said Tricky Ricky - although I didn't wedge the throttle open. Will run through it few more times tomorrow to ensure I've done it consistently across each cylinder, and will run a hot test when I've re-assembled everything. Used just a cap full of oil for the wet test but will compare to the other cylinders tomorrow.
Car feels good when driving so no worries - was just interested to see how it's doing.
Edited by evest
Doesn't hurt to double check things, no disrespect to the OP, yes wedging open the throttle allows maximum air flow into all cylinders,
I just found the 45psi difference on cylinder 5 a bit excessive, so could well be worn rings, however given the mileage I would have been inclined to wet test the rest just to see, however as I said its a pretty good figure for the mileage.
a leak-down test would give a more comprehensive idea of the condition.
