Hi guys and gals .. Z is up on axil stands as its on sorn .... so I got under and had a look round and found that there is oil around the back of the gear box .. Cant see where its coming from ... might be rear box seal .... So does any body know what sort of job it is the change the seal please ??
Thanks all JC :teeth:
Just drop the prop and sleeve and dig out the rear gearbox seal. Clean up and fit new seal and refit sleeve and prop..
Edited by ZMANALEX
You make it sound so easy :)
