313 HR aux belt
chrisday1990
You do not require the fan deck removed.
The belt tension is adjusted by the movement of the spring loaded tensioner pulley.
Simply check the position of the notches to determine if there is a belt issue.
Alex. :)
Edited by ZMANALEX
Alex. :)
Thanks Alex
Checked it out all was ok, when I turn AC on the pulley clutch engages and sound goes, I sprayed some wd40 into the groves at front and has since stopped, may possibly need to inject some copper slip Greece?
