Fuse for boot light & number plate light ?
Hey chaps,
I've noticed that the right hand bulb on the rear number plate has stopped working, as well as the interior boot light. I've just no idea where the correct fuse for it would be, probably best to check this first as they are new LED bulbs.
Cheers !
Both of the number plate lights and your front side lights and I believe side indicators are all on the same fuse. Therefore, because you still have one number plate light working I don't think it is the fuse. However, if you want to double check then in the drivers foot well, there is a removable panel on the right hand size that contains the fuse for the lights.
Wiring issues or perhaps just a bad/poor connection.
Avoid the guess work and just stick a meter on it to see if you have feed.
Ah, yep, makes sense, I'll do that on Sunday, and it could just need a clean I presume (at least the number plate one).
