Ceejay29 Posted August 18, 2014 Posted August 18, 2014 (edited) So I want to add what I believe to be a water temperature sensor/gauge to the engine bay; I think I have seen a few examples on the forum and have found a mishimoto example but have no idea how a gauge is connected. They seem to be located where the bleed nipple/screw is. I have probably seen the examples spoke of on FI zeds and could be mistaking this gauge for something else but worth a query! Edited August 18, 2014 by Ceejay29 Quote
ZMANALEX Posted August 19, 2014 Posted August 19, 2014 Best to fit the sensor to the top radiator hose. Alex. 1 Quote
Ceejay29 Posted August 19, 2014 Author Posted August 19, 2014 Ok thanks Alex, could you point me in the right direction or am I heading along the right lines with the Mishimoto rad hose sensor adapter? Quote
ZMANALEX Posted August 19, 2014 Posted August 19, 2014 Link required to the adaptor that you are referring to for my informed view. Alex. Quote
Ceejay29 Posted August 19, 2014 Author Posted August 19, 2014 http://www.mishimoto.co.uk/mishimoto-32-mm-water-hose-connector.html Two examples of what I am referring to. This could be turbo related as it is an R33; Second example is quite a set up and most definitely FI, although I have seen a similar set up simplified that I believe to be on an NA set up. Hmmmm? Quote
Ceejay29 Posted August 19, 2014 Author Posted August 19, 2014 Could be oil temp or boost gauge? I have no idea but would like to emulate something similar for aesthetics Quote
ZMANALEX Posted August 19, 2014 Posted August 19, 2014 That is not what you require for a temp sensor. If you have the gauge and sensor then all you require is something like this: http://www.ebay.co.uk/itm/like/200972665328?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108 Alex. Quote
Ekona Posted August 19, 2014 Posted August 19, 2014 (edited) That's a fuel pressure gauge, if I'm not very much mistaken. *EDIT* In the pics, not your adaptor tee Alex! Edited August 19, 2014 by Ekona Quote
Ceejay29 Posted August 19, 2014 Author Posted August 19, 2014 Haha! Ok thought I might be slightly off Quote
Ceejay29 Posted August 19, 2014 Author Posted August 19, 2014 That is not what you require for a temp sensor. If you have the gauge and sensor then all you require is something like this: http://www.ebay.co.uk/itm/like/200972665328?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108 Alex. Ok so I can fit a gauge to your example or am I completely missing the point? Quote
ZMANALEX Posted August 19, 2014 Posted August 19, 2014 No, you fit the sensor to the adaptor. The gauge goes inside the car. Why would you want a temp. gauge in the engine bay you Wally. unless you have x-ray eyes. Alex. Quote
Ceejay29 Posted August 19, 2014 Author Posted August 19, 2014 Why would you want a temp. gauge in the engine bay you Wally. unless you have x-ray eyes. Alex. for aesthetics. Thanks for you help (and patience Alex) Quote
Ekona Posted August 19, 2014 Posted August 19, 2014 Just stick a gauge there anywhere then, don't connect it to anything. Quote
Ekona Posted August 19, 2014 Posted August 19, 2014 I was only half joking. If you want it for the look, just buy a gauge and connect a short bit of hose to it, then run that hose down to somewhere no one will ever see and leave it there. Saves the cost and the hassle. Quote
