After 85k and ten years my banana arm bush has died.
So I've just bought a full front end set of the Superpro Polyurethane ones from H-Dev.
I need to get a tool to split the ball joints upper and lower so I can get the arms off for pressing the new bushes in. Is there any specific 'size' I need or can someone recommend a suitable tool that isn't a fortune?
Also do I need something to remake the joints after they have been split?
I plan to buy new nuts for the ball joints after reading a couple of threads on here.
Thank you
Steve
Posted (edited)
I use a lump hammer - not expensive :)
A spanner or socket is all that is needed to pull them back together.
Loosen the nut (after removing the split pin) give the ball joint a clout (not stupidly hard) on the side of the bar it fits through it should pop out.If not put the nut on and tighten it until about 1 thread is left and a sharp tap on top that should break free it they have inserts so should not need any more persuading most will fall apart.
If you do use a tool be careful as the rubbers are very easy to split.
Good luck
Edited by Keyser
