I have just purchased a replacement steering wheel as mine was in dire condition. The replacement is exactly the same as the original, switches etc. it also comes with the airbag fitted. Will this be a straightforward swap? Any gotchas to be aware of?
None at all, assuming it is identical and none of the connectors are damaged.
Do disconnect the battery first before doing anything with airbags, just in case. Oh, and leave the nut on the thread a couple of turns whilst you try to wiggle the wheel free from the column: If you don't, you'll end up using so much force it'll come off suddenly and smash you in the face.
/VOE :(
