Just been to view a car, temperature rose and didn't really drop down, fan didn't kick but possible ddidnt leave it running long enough, noticed expansion bottle was at min point but had coolant in it are these known to use coolant and if so what is usually the cause? Thanks.
Should not use coolant, however the level will change in the expansion tank as the coolant temperature increases and decreases.
The coolant level should only be checked when cold and at that time should be on the maximum mark.
Alex. :)
Make sure the fans kick in if you are about to purchase. Fan failure is common on the 350. One quick way is to turn the air conditioning on.
