addisj Posted May 27, 2014 Posted May 27, 2014 The perferated door cards look a little blotchy under the light. i tried using interior cleaner on them and it hasn't helped. I am wondering if this is a common problem and if there is a solution I can use that will eliminate it? Cheers Quote
Randy_Baton Posted May 27, 2014 Posted May 27, 2014 I've got the same issue, I've hit them with everything and only slightly improved it. I've used neat white spirit, APC, speed wipe. I was thinking of using a machine polisher to up the elbow grease! Quote
RJF Posted May 27, 2014 Posted May 27, 2014 Mine are the same... Read an article in the past that recommended using a heatgun on low heat to restore a scuttle panel "back to black", so might try that when I'm feeling brave! Quote
-Bradders- Posted May 27, 2014 Posted May 27, 2014 mine are the same too, looks like greasy hands have been all over them, tried several things not made a difference, heat gun sounds like a good idea! Quote
GIXXERUK Posted May 27, 2014 Posted May 27, 2014 It's a big area but you could use forever black Quote
GIXXERUK Posted May 27, 2014 Posted May 27, 2014 (edited) Double post ! It's a dye. So it will coat and cover the marks Edited May 27, 2014 by GIXXERUK Quote
herorich Posted May 27, 2014 Posted May 27, 2014 I have exactly the same problem, not damages or scratched, just blotchy. Surely there is a solution? Sent from my SM-T310 using Tapatalk Quote
