Trig Posted April 12, 2014 Posted April 12, 2014 Hi all after a good running engine for a project let me know what you got or know off cheers. Quote
Vlad Posted April 15, 2014 Posted April 15, 2014 a bit late reply, but if you still need one - I think Keyser had 1 spare (may be more than one knowing them lot ) 1 Quote
Keyser Posted April 15, 2014 Posted April 15, 2014 a bit late reply, but if you still need one - I think Keyser had 1 spare (may be more than one knowing them lot ) Â Â What are you trying to say Vlad? Â We have 3 but none are "good runners" Â 1 has already had the vultures at it the other 2 both need bearings sorted (bottom end) Â So ZmanAlex is probably the OP's best bet Quote
Vlad Posted April 15, 2014 Posted April 15, 2014 I'm trying to say if you using engine blocks as door stops - im sure you have more inside The Shed 1 Quote
Trig Posted April 16, 2014 Author Posted April 16, 2014 How much for one needing bearings??? Cheers. Quote
brother_david Posted August 7, 2014 Posted August 7, 2014 To late? Â 80k mls VQ35DE, Plenum spacer. Ran fine before i removed it, no weird smell, no leaks etc. Quote
Shades Rs Posted August 7, 2014 Posted August 7, 2014 PM sent buddy, I have one running and sounding sweet. Low miles too, mileage verified. Cheers   Sent from my iPhone using Tapatalk Quote
Trig Posted August 7, 2014 Author Posted August 7, 2014 Sorry guys not been on for a while something else came up but that's sorted now the project car is home and being stripped. I have done a lot more research into these engines and the bottom ends do seam to be a big problem with them? Â I don't mind rebuilding a engine but don't want do be doing it every year or even mid session need it strong and reliable. Quote
Keyser Posted August 8, 2014 Posted August 8, 2014 How much for one needing bearings??? Cheers.  Not much - been sitting there a while depends if you want all the ancillaries they are worth more than the engine  Drop me a PM if you want more info Quote
Trig Posted August 8, 2014 Author Posted August 8, 2014 If it's cheap I'll take a engine that's fooked I can build it to my own spec at a later date but need sump block heads to line things up as I build the car. Quote
brother_david Posted August 11, 2014 Posted August 11, 2014 Well.. mine wont be cheap i guess since its a runner, unless you count 'bout 1200 £ cheap that is. Will have to ship it from Sweden too since i imported it here from the UK. Quote
Trig Posted October 2, 2014 Author Posted October 2, 2014 Got one this week engine complete with all ansiarys and gearbox half a prop full loom and ECU. I spoken to quaife they do a bellhousing for my box to fit the Z so just wondering what the gearboxes are worth??? Maybe go aftermarket ECU too? Quote
