Dannyg Posted March 5, 2014 Posted March 5, 2014 Hi all Car seems to go dead on me Twice today I've gone to unlock my car, and nothing had to get in with the key, start it up and it works fine but radio and Speedo resets which would suggest the batteries gone flat temporarily, battery is only 6 week's old, when driving volt gauge is at 14v but I'm sure it normally its at 15v and with the keys in but not cranked its at 8v Any ideas? duff battery? Quote
KyleR Posted March 5, 2014 Posted March 5, 2014 Sounds like something is draining the battery. It should be at 12 with the key in and 14.4+ with the car running. Quote
Dannyg Posted March 5, 2014 Author Posted March 5, 2014 (edited) That's what I thought but I haven't left no lights or heated seats switched on, it wouldn't be the show and go number plate would it lol, had that on for a month and haven't had any issues with it, that works with out the keys in Edited March 5, 2014 by Dannyg Quote
GIXXERUK Posted March 5, 2014 Posted March 5, 2014 have you checked the battery connections ? if the show n go is fused which it should be, take the fuse out, just to see Quote
Dannyg Posted March 5, 2014 Author Posted March 5, 2014 (edited) Yea,connections are fine.. just put a battery/alternator test and all was good, but then I guess it would be if the Car worked when I unlocked it, I'll try the fuse now Thanks Edited March 5, 2014 by Dannyg Quote
Briggsybriggs1 Posted March 5, 2014 Posted March 5, 2014 I had a problem with my battery it was the + And - not on very good so nipped them up and all ok, or if it's a new battery it could be faulty I would take it back to were you got it from, Sent from my iPad using Tapatalk Quote
Dannyg Posted March 5, 2014 Author Posted March 5, 2014 Yea that's what I might do but they will end up testing it to make sure and it will be ok, because it only happens now and again, so they may not accept it back Quote
350zedd Posted March 5, 2014 Posted March 5, 2014 Have you tried connecting an ammeter or multimeter (set to amps) in series with a battery lead ? This would show if there is any significant current flow discharging your battery with everything switched off. 1 Quote
Dannyg Posted March 5, 2014 Author Posted March 5, 2014 Not yet haven't got one at home, think there's one at work so will try that tomorrow too thanks Quote
Dicky Posted March 5, 2014 Posted March 5, 2014 Have you tried connecting an ammeter or multimeter (set to amps) in series with a battery lead ? This would show if there is any significant current flow discharging your battery with everything switched off. I did this on mine recently and without the alarm activated and engine off the current drain was 0.4A. I assume this drain would be keeping the computers active. With the alarm activated the drain was 0.7A. Assuming the batt was fully charged for it to be at 8 v when the engine is off seems to indicate some high current is being demanded from somewhere, hence dropping the voltage. But to drop the voltage by 4v would take a lot of current being drawn and if into a faulty component to would get quite hot and smelly, unless something like a heated rear screen. The battery could be iffy but seems unlikely given it's only 6 wk old. I would have a load test done on the battery to confirm its ok. They put a resistance across the batt terminals and it should maintain the voltage at some level for it to be considered ok. Hope any of this helps. Quote
Dannyg Posted March 5, 2014 Author Posted March 5, 2014 Thanks dicky Gunna try everything tomorrow at work where theres lights and proper equipment lol Thanks again all, your help is appreciated Quote
