DaddyCee Posted February 19, 2014 Posted February 19, 2014 Hi All. Probably a front bush issue (fnarr fnarr). But before I get the car up on a ramp just wondered what some of the culprits would be to check for. The clunking only occurs when riding over potholes and they are not what I would consider as being deep. The banana bushes on both sides were only changed out last year, so I will be bemused if it is one of those. Cheers, DC. Quote
370Ad Posted February 19, 2014 Posted February 19, 2014 Drop link can cause clunk, ball joint on banana arm is also possibility. Quote
AliveBoy Posted February 19, 2014 Posted February 19, 2014 I'd probably recommend not driving over potholes But as above, drop link, ball joint or banana arm would be the normal suspects. Quote
Ewen@Clark Motorsport Posted February 19, 2014 Posted February 19, 2014 As above compression arm ball joints or drop links would be worth checking. We keep a number of options in stock should you require Quote
DaddyCee Posted February 19, 2014 Author Posted February 19, 2014 ok thanks for the advice. i'll come back to you with an order when I know what needs replacing. Quote
ersen.o Posted February 19, 2014 Posted February 19, 2014 Always seemed to be the banana arm for both my Zeds Drop links make a creaking noise? Quote
The Trouser Posted February 19, 2014 Posted February 19, 2014 I had the same - see here http://www.350z-uk.com/topic/68596-clunking-on-passenger-front-wheel/page__hl__plywood#entry1021536 Turned out to be the front suspension arm Quote
DaddyCee Posted February 19, 2014 Author Posted February 19, 2014 oops completely forgot about that thread. Quote
