fairladyz2013 Posted December 24, 2013 Posted December 24, 2013 Hi all., Â I noticed that whilst going backwards only (reverse or just letting it roll back in neutral) my zed has this squeal noise. :/ Â Anyone know what this could possibly be or experienced this before? Â Thanks in advance for any help. Â Â Â Quote
bamdc2 Posted December 24, 2013 Posted December 24, 2013 Maybe something catching on discs/brakes? Or axle needs greasing? Quote
Neilp Posted December 24, 2013 Posted December 24, 2013 My guess is brake pads. Have you check them recently? Even when they look ok, if you take the out, they can be crumbled in bits and this can generally cause a squeal, albeit usually when going forwards. Quote
Ebized Posted December 24, 2013 Posted December 24, 2013 I would say it is more likely coming from the handbrake hubs that might just need a good clean out. Quote
Flex Posted December 24, 2013 Posted December 24, 2013 Are you sure there's not a cat in your wheel arch? Sorry Quote
Neilp Posted December 24, 2013 Posted December 24, 2013 I would say it is more likely coming from the handbrake hubs that might just need a good clean out. Â Yes it could be this also. Mare of a time for someone who hasn't got ramps and a big breaker bar to get the rear caliper off before removing the rear discs/hub unit Quote
