stu1986 Posted December 14, 2013 Posted December 14, 2013 Hi all Anyone know a way I can get auto door locking on my 2009 370Z GT Ultimate? Even if it's a separate module I don't mind Quote
GIXXERUK Posted December 14, 2013 Posted December 14, 2013 The automatic door lock function ON/OFF can be switched by performing the following operation. 1. Close all doors (door switch OFF) 2. Turn ignition switch ON 3. Press and hold the door lock and unlock switch for 5 seconds or more in the lock direction within 20 seconds after turning the ignition switch ON. 4. The switching is complete when the hazard lamp blinks. OFF → ON : 2 blinks ON → OFF : 1 blink I haven't tested it :-) Quote
GIXXERUK Posted December 14, 2013 Posted December 14, 2013 And ... To change between selective unlock enabled or disabled (default): Selective Unlock - Enabled When an LOCK signal is transmitted from Intelligent Key, all doors and fuel lid are locked. When an UNLOCK signal is transmitted from Intelligent Key once, driver side door and fuel lid are unlocked. Then, if an UNLOCK signal is transmitted from Intelligent Key again within 60 seconds, all other doors are unlocked. Selective Unlock - Disabled When an LOCK signal is transmitted from Intelligent Key, all doors and fuel lid are locked. When an UNLOCK signal is transmitted from Intelligent Key once, all doors and fuel lid are locked. Enabling/Disabling Selective Unlock When LOCK and UNLOCK signals are sent from the Intelligent Key for more than 5 seconds at the same time, hazard warning lamp blinks and Selective Unlock feature will toggle (enabled -> disabled or disabled -> enabled) Quote
GIXXERUK Posted December 14, 2013 Posted December 14, 2013 I knew it would happen one day ... Correct lol Quote
stu1986 Posted December 19, 2013 Author Posted December 19, 2013 what does this work for 2009 models also?? Quote
R35LEE Posted December 19, 2013 Posted December 19, 2013 Works on all 370z models mate I believe Quote
Ebized Posted December 19, 2013 Posted December 19, 2013 Works on my 2009 370 - amazed that you have not used the option to date as its so much easier using the buttons to unlock the doors/boot rather than fishing around for the key. Quote
stu1986 Posted December 23, 2013 Author Posted December 23, 2013 It doesn't seem to work on my car Quote
