Cozzi Posted October 9, 2013 Posted October 9, 2013 I currently have a HID kit fitted to my 03, I know its an aftermarket kit because im sure they are about 8k temp. My question is what bulb type would a prefacelift 350z take in the headlights, High and dipped beams.. Thanks. Quote
Cozzi Posted October 14, 2013 Author Posted October 14, 2013 Someone must know the answer to this? Quote
hensh65 Posted October 14, 2013 Posted October 14, 2013 Just checked recomended bulbs for my reg and this bulb came up http://www.eurocarparts.com/ecp/c/Nissan_350Z_3.5_2005/p/car-parts/car-electrics-and-car-lighting/lighting1/car-bulb/?48177042V&1&0ca99bf4d3af2422a4b98771cb9209398b6a22ca&000384 Hope it is of some help Quote
Dblock Posted October 14, 2013 Posted October 14, 2013 I currently have a HID kit fitted to my 03, I know its an aftermarket kit because im sure they are about 8k temp. My question is what bulb type would a prefacelift 350z take in the headlights, High and dipped beams.. Thanks. My JDM has standard oems and it's about 8k too. You can just change the bulbs. Do you want to know firmament for a hid or none hid car. Also you would know by the wiring and ballast if it was oem of not. Quote
Cozzi Posted October 14, 2013 Author Posted October 14, 2013 You're saying the HID's that are in at the moment could be stock? I assumed they were after market because they look to be about 8K Quote
Dblock Posted October 14, 2013 Posted October 14, 2013 They could be. It's the bulbs that dictate colour nothing else. Quote
marzman Posted October 14, 2013 Posted October 14, 2013 Dblock is correct. Just because they're 8000k doesnt mean the whole kit is aftermarket, just the bulbs have been changed probably. The standard bulbs you need are D2R's, and you should be able to pick a pair up for under 20 quid on eBay. Quote
Cozzi Posted October 15, 2013 Author Posted October 15, 2013 Ok thanks, assumption is the problem here lol. Ill look into it further. How bright are peoples headlights? I find mine seem to be lacking slightly, another reason i thought they may be a cheap ebay kit. But they may just be cheap bulbs then. Quote
KyleR Posted October 15, 2013 Posted October 15, 2013 Take one of the splash guards off under the arch and you'll see an after market ballast in there if there is one, otherwise there'll be a 3" x 3" black metal box attached to the bottom of the headlamp unit with a grey clip from the loom attached. If you google 350z ballast you'll see what you're looking for. Quote
Dblock Posted October 15, 2013 Posted October 15, 2013 350z pre bi xenon headlights are terrible. Quote
