Ceejay29 Posted October 7, 2013 Posted October 7, 2013 Hi Guys, I am about to fit a pair of LED tail lights, am I right in thinking it is simply 'plug and play?' Thanks Quote
WhackyWill Posted October 7, 2013 Posted October 7, 2013 Yes should be, are they genuine Nissan or OEM ? 1 Quote
peteman35 Posted October 7, 2013 Posted October 7, 2013 Yes should be, are they genuine Nissan or after market? Corrected Quote
WhackyWill Posted October 7, 2013 Posted October 7, 2013 Don't expect me to get everything right, I'm in the pub...!!! 2 Quote
mattross1313 Posted October 7, 2013 Posted October 7, 2013 Mine we almost plug and play. Had to trim a small slide of plastic off the plug connector on the car. Easy enough though 1 Quote
WhackyWill Posted November 9, 2013 Posted November 9, 2013 Mine we almost plug and play. Had to trim a small slide of plastic off the plug connector on the car. Easy enough though Hi Matt. Got any info on how to shave the plug as I got a set of LED to fit and the plugs are different. Thanks. Will. Quote
KyleR Posted November 9, 2013 Posted November 9, 2013 there are small guides on the male part of the connector (on the light) that are a perfect mirror of the pre facelift ones. They just need filed off to fit in the female. It's so obvious what you have to do when you get the old ones out. Quote
mattross1313 Posted November 10, 2013 Posted November 10, 2013 Hey Will, sadly not - Buster fitted them for me at the Zed Shed. When he pulled out the snips to make the plugs fit he told me to go put the kettle on haha! Looks like Kyle has te solution though Quote
WhackyWill Posted November 10, 2013 Posted November 10, 2013 Hey Will, sadly not - Buster fitted them for me at the Zed Shed. When he pulled out the snips to make the plugs fit he told me to go put the kettle on haha! Looks like Kyle has te solution though Thanks Matt. I figured it out, all fitted now. Thanks for your input. Quote
