Alessio Posted September 17, 2013 Posted September 17, 2013 hello friends, I got a 2005 350z Lev.1 Times ago i was changing the interior dome lights from halo to led, Well, i made some short there. Changed the fuse, and i noticed that the dome lights now works only in manual way (by clicking) even if the switch is in "door" mode. Well, i read tooons of post about it. Lot of people fixed it in different ways, here's what i tried without success. 1 - Check all the fuse in all the fuse box. everything's good. 2 - Unplug the battery for 10 miuntes 3 - Unplug the bcm for 10 minutes 4 - Ecu manual reset procedure Some tips? Thanks, Alessio Quote
Neilp Posted September 17, 2013 Posted September 17, 2013 Bcm will be fried if it has shorted usually. There's a guide on here to fix the issue I'm sure. Quote
Alessio Posted September 17, 2013 Author Posted September 17, 2013 Bcm will be fried if it has shorted usually. There's a guide on here to fix the issue I'm sure. Quote
Alessio Posted September 17, 2013 Author Posted September 17, 2013 Hi. Can you link it plaese? English is not my 1st language and its hard to me to find stuff there Thanks Quote
marzman Posted September 17, 2013 Posted September 17, 2013 http://www.350z-uk.com/topic/74831-bcm-dome-interior-light-dim-repair/ Quote
ZMANALEX Posted September 17, 2013 Posted September 17, 2013 English is not Neil's first language either :lol: Alex. 2 Quote
Neilp Posted September 17, 2013 Posted September 17, 2013 English is not Neil's first language either :lol: Alex. lol cheeky sod! Quote
Alessio Posted September 17, 2013 Author Posted September 17, 2013 Ahhahahahah.... thanks you all guys. I did. I took off the bcm.. i fried a contact. I welded a new one and now it works. Damm still cant get why it fried the contact and not the fuse. Thanks again ; ) Alessio Quote
