what size spacer can i get away with ??
just bought some 19" alloys for the car front-19x8.5 et35 rear 19x9.5 et30 tyre size front 245x35x19 rear 275x35x19 i was looking at getting 30mm spacers just for the rear would that be okay to do??
Those already stick out a further 16mm than the rays wheels on the rear. I use this website for offsets: http://www.1010tires.com/Tools/Wheel-Offset-Calculator
As its suggested that the rays have a 25mm spacer, you could get a 10mm spacer but I wouldn't recommend any more than that. The fronts however only stick out a further 1mm, so you could get a 20mm on those.
Edited by Gudzy
I Have 25mm spacers on the rear and 20mm on the front with 245 and 275 19's... I had to roll my arches on the rear so the lip didn't catch the tyre... I am also running -1.5 degree camber on the rear......Also had to roll the front but the front is lowered unlike the rear....PSS on the rear and assy 2's on the front.... rolling your arches is easy as long as you have patience and about 2 hours...
Just remember u don't want more then 25mm offset max, including wheel and spacer. That gives it pretty much the perfect look, it's very flush with the body work. If you lower the car you could go a little wider.
Make sure spacers are steel, not aluminium..
Sent from my GT-I9300 using Tapatalk 4
