fellsteruk Posted August 30, 2013 Posted August 30, 2013 Hi all, I have seen a fix on the forums for a dodgy fuel gauge but i wanted to check if what i have is the same issue and if so do you think i would get it sorted on warranty? I first noticed the issue when i filled the car but the fuel gauge would only show just under the Full line as shown here, i then noticed that the needle would drop a fair bit very quickly. I decided to leave it until the fuel light came on and noticed that i was driving around on "almost empty" for a while before the light came on: Here is what its showing after just 104 miles: My MPG and DTE seems to be reporting a normal figure, My MPG is about 27 and DTE is reporting about 250 miles left which with 104 already done is about right for me. Is this the same issue other have had, is it easy/cheap to fix or do i have a different issue all together? Thanks Stephen Quote
fellsteruk Posted August 30, 2013 Author Posted August 30, 2013 I have warranty till end of Sep so ideally i want it fixing under that.. "fingers crossed"!!!! Quote
Ebized Posted August 30, 2013 Posted August 30, 2013 Not an uncommon problem http://www.350z-uk.com/topic/54763-how-to-fix-the-inaccurate-fuel-gauge/ Quote
KyleR Posted August 30, 2013 Posted August 30, 2013 Same problem, just don't try to do 400 miles on a tank and you'll be fine. Reset the trip and mpg computers each time you fill up and calculate it from that if you need to know how much is in there. Personally I just run about 30-40 miles on the light and then stick about 70 litres in it. Quote
peteman35 Posted August 30, 2013 Posted August 30, 2013 What mine did. Means your lucky like me and only one of your fuel level senders is mucky. You have a 50% chance of getting it right. Good luck Quote
SteveW Posted August 30, 2013 Posted August 30, 2013 The drivers side sender is the primary one Quote
fellsteruk Posted August 30, 2013 Author Posted August 30, 2013 Great guide but as i still have warranty i am going to ring in the morning and see if i can get it fitted in to be sorted, dont mind doing it myself but if i can would rather the nissan dealer sort it.. I wonder if they will cover it Quote
fellsteruk Posted September 3, 2013 Author Posted September 3, 2013 Great nissan said they will do it on the warrantee, goes in next week saves me a big job Quote
