mrchic Posted August 12, 2013 Posted August 12, 2013 Whilst going through the process of removing my rear bumper i snapped two 10mm bolts at the very bottom of the bumper.(each side) In hindsight maybe i should of sprayed some WD, but the bolts were turning. Would you guys attempt to remove them, or drill new holes adjacent. there probably two small to drill out? Thanks Quote
mrchic Posted August 12, 2013 Author Posted August 12, 2013 Drill out and re-tap the holes if required. Many Thanks Something like this i need http://www.screwfix.com/p/screw-extractor-5-piece-set/18643 Quote
Lexx Posted August 12, 2013 Posted August 12, 2013 Not quite what I meant. With the screw head being small. I meant to drill out to almost the diameter of the screw itself (it can be done with a steady hand). Then if needed use an appropriate size tap to put the thread back in (I don't know the thickness of what it screws into, so don't know if it is actually threaded or not. Quote
Keyser Posted August 12, 2013 Posted August 12, 2013 You can try them - grind the end flat (or file) centre punch then drill it out I start small and work up to as big as I can - try the extractor if that fails drill to just below thread size and run a tap through it - sorted Quote
Jp606 Posted August 12, 2013 Posted August 12, 2013 (edited) For what it's worth, that screw extraction set from screwfix is crap. I bought them for use on another car that had a sheared bolt and they snapped on first use. Bought a set of cobalt drill bits instead and they went through the metal like a hot knife through butter. Edited August 12, 2013 by Jp606 1 Quote
mrchic Posted August 12, 2013 Author Posted August 12, 2013 (edited) Thanks for the suggestions Will try the drill method And i need a Tap and Die set? Edited August 12, 2013 by mrchic Quote
