Lower Arm Bushes - Dead
RickyZ
Compression arm bushes are a common fault. I had the knock on uneven ground and replaced the bushes with the super pro kit. However it hasn't cured the problem. After reading the forums it sounds like it could be the ball joint bush on the compression arm. This part isn't available to change on its own so a whole new arm may be needed.
