Lower Arm Bushes - Dead
were you getting a rattling noise from the car over uneven roads? currently suffer from rattle myself, everything i've read suggests its the compression arm bushes, but want to be sure before i fork out £200 to replace them!
Compression arm bushes are a common fault. I had the knock on uneven ground and replaced the bushes with the super pro kit. However it hasn't cured the problem. After reading the forums it sounds like it could be the ball joint bush on the compression arm. This part isn't available to change on its own so a whole new arm may be needed.
hmmm, will try and get up on a ramp to see if i can identify whether its the compression arm bush, the ball joint, or maybe even the front lower arm bush :headhurt:
It usually very difficult to establish any sort of wear or movement in the joints / bushes as you can not re create the weight of the car going over a bump on a ramp.
Wow what great customer service with the video!
Genuine bushes £28 delivered from the US if the traders can't sort you out B)
