P1 service
Stew
I need one. What should I supply - it will NOT be going to a nissan stealer.
I would like to supply everythig - looking for good stuff so makes and model numbers are appreciated.
Thanks!
Maybe need more help than that, I can sort out the filter easily enough - I guess that it's not worth getting a fancy one.
I relly don't know what oil is best. Mobil one? Amsoil? Others???? Which number should I get?
36k miles gets you a P3 service (the most expensive service)
280 quids gets you...
Oil
Filter
Brake Fluid
Air filter
Standard Gubbins checks (greasing hinges, screen wash etc...)
They will run a Diagnostics and check the ECU (not sure they do anything after checking through... :dry: )
They'll tell you if you need your pads replacing... ( which is extra money in their pockets if you change them... )
If you are very caring over you car etc... you could have the T/M oil and RR Diff Oil replaced... ( it is indicated for 36k service, but Zeds actually don't need them...) but this will be extra cost...
Overall it feels like the dealer has inserted a bit shaft up yours and you gladly payed for it... while he's laughing at you. :rant:
If your car is not in warranty go to a specialist...
you'll probably get all of the above better done and at a lower cost...
If it is in warranty figure out if you think you are going to need the warranty left unchallenged... (personally I wish I took it to a specialist)
Oil
Filter
Brake Fluid
Air filter
Cheers for that! :thumbs: It's still under warranty, so I think I'll take the shaft one more time. 1...2...3.......clench :blink:
Oil
Filter
Brake Fluid
Air filter
Phone around mate, that's what I did with my last one. The cheapest I found was the East Side of Glasgow Arnold Clark. They gave me a price, I then phoned Parks headquarters and they beat it slightly, plus the garage is closer.
