Bobbyheinz Posted December 8, 2012 Posted December 8, 2012 Hey guys, I left my car at the train station for a week while I was away for work. I came back and it was completely dead, didn't even turn over. I jump started it and managed to get home. Tried it again this morning and it tried to turn over but just made a clicking noise. Jump started it again and took it for a good drive and have stopped and started a few times since and it's been fine. Â Is it just going to keep dying and I'd be best to just replace the battery? Quote
glrnet Posted December 8, 2012 Posted December 8, 2012 Ok, it was cold this week but that shouldn't knock a good battery over. If you didn't give it much chance when you drove home from the station, headlights, heater on etc then it wouldn't have recovered from that hence the flat battery again this morning. It's on the way out I should think, take it in to a local garage and have them put a battery tester across it if you like but if it were me I'd buy a new one and be done with, assuming your alternator is charging correctly of course. If your battery is weak then the cold weather wil always find it out. Hope this helps. Quote
Goldcrest Four Posted December 8, 2012 Posted December 8, 2012 Sees like your battery has expired Buddy; if the car restarted after a run the alternator is probably charging OK and the battery isn't retaining the charge. You can get a reasonable quality replacement for £60-£70. Ask a battery supplier to give the suspect battery a load test before you buy. Quote
Bobbyheinz Posted December 8, 2012 Author Posted December 8, 2012 Cheers gents. I noticed that it's a BMW battery and only 50ah…that seems a little low?? Quote
glrnet Posted December 8, 2012 Posted December 8, 2012 Yep, I think the Zed one should be 65-70ah Quote
Bobbyheinz Posted December 8, 2012 Author Posted December 8, 2012 Cheers I thought so. Oh well looks like it's off to buy a new one then! Quote
Dblock Posted December 8, 2012 Posted December 8, 2012 Cheers gents. I noticed that it's a BMW battery and only 50ah…that seems a little low??  Pff thats fine, my old battery was 40ah and 330cca. Quote
rtbiscuit Posted December 9, 2012 Posted December 9, 2012 Order online you have more choice and good prices. I got mine online. Go for something like a Bosch battery like their s5 silverline. I just changed my jag one. Worth it if the winter is as bad as they think Bosch ones come with a 5 year warranty. Â Sent from my HTC One X using Tapatalk 2 Â Â Quote
choptop Posted December 9, 2012 Posted December 9, 2012 Order online you have more choice and good prices. I got mine online. Go for something like a Bosch battery like their s5 silverline. I just changed my jag one. Worth it if the winter is as bad as they think Bosch ones come with a 5 year warranty. Â Sent from my HTC One X using Tapatalk 2 Â Top advice. Â Costco is good for batteries. If you have a later 350z model you will also have to take out the windscreen scuttle. Quote
4RE Leather Posted December 9, 2012 Posted December 9, 2012 Could you have by anychance left the interior light on? Quote
