Pendle7 Posted August 22, 2012 Posted August 22, 2012 Hi all, just picked up my 350Z tonight. First thing I do is try to move the seat forward but it's not moving!!!! They are electric, the lean/tilt on the back of the seat is working but I just can't move the bottom bit forwards/backwards so I can get closer to the pedals!! Can anyone point me in the right direction?? Thanks, Mark! Quote
DoogyRev Posted August 23, 2012 Posted August 23, 2012 Check the connector is clipped together correctly under the seat Quote
Keyser Posted August 23, 2012 Posted August 23, 2012 Shake the back / forwards switch vigorously - not violently as in don't break it just give it a good work out. I'm sure I recall a thread with the exact same thing and it was just that the switch had not been used for a while. If that fails and as Doogy said you have check the connections then its investigation with a multi-meter Quote
coldel Posted August 23, 2012 Posted August 23, 2012 Tap the top of the switch for about ten seconds, might just be the connection Quote
Pendle7 Posted August 24, 2012 Author Posted August 24, 2012 i think the seat had dropped off the limit switch at the back. i pushed it forward and it works now. cheers though! Quote
