Gaz350 Posted December 19, 2011 Posted December 19, 2011 Hi Guys, first may I apologise incase anyone has already asked this (I have searched for a relevant topic but all to no avail). But is there a how to guide for removing the rear wiper and washer mechanism? If not would some kind soul mind writing one up for me, I would hate to damage my pride and joy by tampering with it so some instructions or hints would be much appreciated! Thanks in advance, Gaz Quote
Lexx Posted December 19, 2011 Posted December 19, 2011 viewtopic.php?f=26&t=46754&hilit=wiper+delete&start=15 Check the last post in the above link Quote
spursmaddave Posted December 19, 2011 Posted December 19, 2011 Been meaning to do this for ages as my rear wiper pump has never worked in 2 years.... I even have the grommets just never got round to doing it.... one day maybe Quote
ChrisS Posted December 19, 2011 Posted December 19, 2011 While the trim is off,take the weight out. Less weight=less fuel use, so you are an eco bunny. Quote
spursmaddave Posted December 19, 2011 Posted December 19, 2011 While the trim is off,take the weight out. Less weight=less fuel use, so you are an eco bunny. Also means when it is cold the boot doesn't hit you on the back of the head Quote
Gaz350 Posted December 19, 2011 Author Posted December 19, 2011 Thanks guys that's fab, will get round to doing it this week sometime, i've got a 25mm grommet for the wiper, but only have 19mm or 22mm for the washer, do you think one of these will work or should I really make sure it's a 20mm grommet (I'd rather be safe than sorry but 1mm seems a very tiny amount to make any real difference!)? Quote
Clarkie Posted December 19, 2011 Posted December 19, 2011 Easiest thing to do is to try them, if it's a good seal you'll be fine. If not nip down to your nearest auto shop and grab one. Quote
Watshot Posted December 19, 2011 Posted December 19, 2011 Doesn't matter if the washer grommet leaks, it goes through to a rain channel anyway. But easy enough to get the right size I suppose, sits right and won't move around. Quote
Watshot Posted December 21, 2011 Posted December 21, 2011 The weight is a counter-weight to make shutting the rear hatch take less effort. Lifting open is not considered a problem as the gas struts assist, then hold the hatch open. However in real life, the struts weaken with age and may not hold the hatch open, as mentioned above. Removing the weight, in theory, puts less load on the struts, and of course there's the age old argument about overall weight saving. In practise, having removed the counter-weight (and the wiper motor etc.), I find the hatch lifts with very little effort, and shuts easily enough not to notice a difference. Just occasionally it may not catch if I'm not commited, in the same way that you sometimes swing the drivers door in a limp wristed fashion and it fails to catch and you have to give it another go. Not a problem really. Quote
Jay Posted December 21, 2011 Posted December 21, 2011 This was one mod I never got around to doing, but it looks so good when done Quote
