problem after service! HELP PLEASE
Mears5
had a service on saturday went to work today and on the way home the engine light came flashed on now there is a chugging sort of noise when the car is running with a kind or clunking or metallic rattle when the clutch is in the raised position i.e. not pressed down any ideas?
You could always get the code, then do the ecu reset.... :shrug:
Noise could be the thrust bearing, a know noise maker... :thumbdown:
Chugging, spark plug loose/.....what service did you have?
Have you opened bonnet and had a look to see if anything is obviously wrong.
Oil cap left off? clutching here really mate :bounce:
yeah opened the bonnet and had a look, nothing noticeable had a p3 service with spark plug change was suggested it could be a plug iv checked all the obvious, will give the code a go and see
cheers for the help though mate it is greatly appreciated
Easy mistake - as Wasso found out on the last Wales weekend.
if it was leads to spark plugs then you would of noticed that immediately after collecting the car from service
