P1147 and P1167 Heated O2 Sensor 2 errors
Adrian@TORQEN
Hi guys,
I keep getting these errors codes lately, random, which I believe they are:
P1147
P1167
Am I right from the above video?
According to the guide: viewtopic.php?f=17&t=21762 they should be:
P1147 Heated O2 Sensor 2
ECU reset clears them, but after few days / weeks the CEL light comes back.
What could cause this and how can I fix it? Anything to do with the cats?
Diag: dtc_1167.pdf
Thanks,
Adrian
Right couple of issues here Im afraid
1/ The codes are not propper Nissan codes, however looking at the data supplied and Riceys link the O2 sensors looks to be the fault.
2/ There isnt really a fix (unless a broken wire that could be soldered)
3/ There is also 2 of these sensors a front or a back they are quite expensive to replace so you need to get the right one!
4/ The cost of the part is £140.40 plus VAT. Please bare in mind this would be subject to a chassis check as the prices can diifer a bit.
My advice would be to get in somewhere that knows what they are doing and get a full diagnostic done on it.
Hope this helps a bit, good luck
