Zugara Posted June 16, 2011 Posted June 16, 2011 Roof leaking via roof seal, anyone got one spare? Alex? Anyone going to USA who could get one for me? http://www.courtesyparts.com/350z-parts ... 6_848.html Part is 76860Q 350Z GLASS RUN-BODY SIDE,FRONT that I need. Or any other solutions welcome.... Quote
ZMANALEX Posted June 16, 2011 Posted June 16, 2011 I should have this in stock mate, however I would require your vin to confirm. Nissan UK price is £404.57 + vat Best that I can do is £364.00 +vat Alex. Quote
Zugara Posted June 16, 2011 Author Posted June 16, 2011 Cheers Alex...... I will PM you my VIN tonight.....Thats a tough pill to swallow Are they renound for leaking just at the end of the seal where there is a little flap of rubber, which I assume gets pinched on the door card? Quote
glrnet Posted June 16, 2011 Posted June 16, 2011 Will might know, didn't he have the same problem? Cheers Alex...... I will PM you my VIN tonight.....Thats a tough pill to swallow Are they renound for leaking just at the end of the seal where there is a little flap of rubber, which I assume gets pinched on the door card? Quote
Zugara Posted June 16, 2011 Author Posted June 16, 2011 Will might know, didn't he have the same problem? Cheers Alex...... I will PM you my VIN tonight.....Thats a tough pill to swallow Are they renound for leaking just at the end of the seal where there is a little flap of rubber, which I assume gets pinched on the door card? Hmmmm, rings a bell, cheers graham. Will PM Will..... Quote
Will370z Posted June 16, 2011 Posted June 16, 2011 Yup same problem, I had all the seals replaced by the garage, made it miles better but I still get leaks in now and again, hardly a trickle but annoying, tbh I've learnt to live with it..... Those seals were very expensive yes, luckily the garage replaced them out of goodwill Quote
HaydnH Posted June 17, 2011 Posted June 17, 2011 I'd try some rubber lubricant on the seals first if they're just old rather than cracked (Holts do a good 1)... and for a couple of quid it's worth a go before splashing out loads on new seals. It worked on my old Mr2 T-Bar which leaked really badly before. Quote
Zugara Posted June 17, 2011 Author Posted June 17, 2011 I'd try some rubber lubricant on the seals first if they're just old rather than cracked (Holts do a good 1)... and for a couple of quid it's worth a go before splashing out loads on new seals. It worked on my old Mr2 T-Bar which leaked really badly before. Cheers mate..... will try that, although I have tucked the offending rubber flap behind the door seal which seems to have solved the problem. Quote
