roscopervis Posted May 13, 2011 Posted May 13, 2011 After a week of trouble free motorfing I have my first proper problem. It seems that Ian, when removing the supercharger etc has lost the clips for the water bypass hose. As a result, it has chaffed on the drive belts, causing a leak. What are the chances Nissan will have this hose in stock tomorrow? Really need the car this weekend! Arggghhh! This is the hose that I need: Any ideas what size this is, any right sized hose will do temporarily. Quote
bronzee Posted May 14, 2011 Posted May 14, 2011 You could also or :pmr35lee: either one might be able to help. Quote
ZMANALEX Posted May 14, 2011 Posted May 14, 2011 You could also or :pmr35lee: either one might be able to help. Thank you bronzee Unfortunately Nissan will not have this on the shelf good to go. Fortunately I do However I can't ship until Monday and it won't be deliverd until Tuesday am. Let me know if I can help you further mate. Alex. Quote
roscopervis Posted May 14, 2011 Author Posted May 14, 2011 I really need a pipe today! The pipe is 1" in diameter so I'm gonna get some generic coolant hose and use that today, before replacing it properly. ZMANALEX, I'll be in touch! Quote
roscopervis Posted May 15, 2011 Author Posted May 15, 2011 Fixed it, the pipe is actually 5/8". Loads of generic hoses out there. Cable tied under the plastic cover to stop it straying, just driven over 400 miles, all is well. Quote
Ian Posted May 15, 2011 Posted May 15, 2011 Bugger, just seen this I'll have a look in the shed to see if I still have some clips in my boxes. Surprised it was rubbing though as its quite a distance away. I also put about 700 miles on it before advertising it for sale, thought it would have had atleast some signs by then Quote
roscopervis Posted May 15, 2011 Author Posted May 15, 2011 That one and one of the electric ones in the ribbed trunking were both handging down. All fixed now. What I have noticed is that I don't have the foam bumper thing that goes behind the front bumper and sits on that big metal cross member. Do you still have that? Other than that it's going well! Quote
Ian Posted May 15, 2011 Posted May 15, 2011 Might be in the shed with the spares I've got, I'll check later for you Quote
