How to - Spark plug change (VQ35DE)
Emperor Ming
Changing the plugs is not difficult but it is fiddly slightly awkward and time consuming.
To get to the plugs there are several items that need to be removed. The strut brace, front cover and intake tubing.
Strut Brace
Loosen off the two locking bolts - 24mm spanner - (They both turn the same way as one end is a reverse thread.) then back off the strut brace tensioner. Turn this a few times to loosen off the brace and then undo the three nuts and one bolt on each end of the strut brace and lift the brace off. If you dont back the tensioner off first the brace pushes itself onto the stud each end and wont pull off!! - I know I did it!!
With the strut brace off taking off the front cover is only 4, 8mm bolts and the intake tube is one bolt on top of the plenum and two jubilee clips
Now comes the awkward bit.
Each plug has its own individual coil pack on the top of the plug cap. This is bolted to the rocker cover with an 8mm bolt and gets its power from two wires connected to the pack by a simple click on connector. Fortunately it is quite a big connector and easy enough to get off with a little squeeze.
The easy way to do it is to remove the bolt that holds the coil pack to the rocker, pull up the coil pack and release the connector. the coil pack can now be removed whilst the plug is replaced.
The back plug on the right hand bank - as you look at the car from the front - and the middle plug on the other bank have small brackets that get in the way of removal. The one covering the back plug can be bent out of the way enough to remove the coil pack but the other one has to be removed. (Only one bolt and easy to get to)
As you are removing the plugs there are several parts of the wiring loom that seem to be in the way but gently pulling them to one side or the other allows the items to be removed.
I replaced the iridium tipped plugs with platinum tipped ones for no other reason than they were the ones that all the books recommended for standard useage.
The plugs I took out - after 22000 miles - were still in good order but showing definate signs of wear.
My car had seemed ever so slightly rough on tick over and this seems to have cleared up but it is too early to say for certain.
Allow a couple of hours for the first time and get yourself a 24mm spanner, a small plug socket with a decent extension and a normal tool kit and its a job any half competant spanner man can tackle.
Ming the Smooth running
Ming
Why did you replace iridium plugs with platinum - what boo told you that was a good idea :scare:
Checked the user manual that I down loaded from here and that gave the code of the platinum plug. Checked with several retailers both on line and local traders and they all listed the platinum plug.
Bought the platinum plug and only when I checked what was coming out did I realise that it was the iridium plug.
It was not a concious 'I will swop those for these ' thing :headhurt:
Ming the Sorted
Guest prescience
Dunno about that mate - I just followed the advice for my FI kit from Vortech. However since the recommended change interval for stock is 60k miles (or something like that) I would be surprised if a platinum plug would last that long wouldn't you?
Guest prescience
Maybe there has been a change though - the latest press release specifically mentions iridium plugs
http://www.350z-uk.com/forum/viewtopic.php?p=34363
Seeing as they only cost about £8 each on spark-plugs.co.uk and I don't think anyone would dispute have a higher spec. I would use them whether I was FI or not .... plug change is 54k miles BTW
Guest prescience
OK for the avoidance of doubt, I have done some digging and the stock plug is indeed platinum and is changed every 54k miles - so I was incorrect in one of my assertions above (the :scare: one), I am sorry :)
I stand behind the others though and your removed plugs look tickety-boo to me
There is however a lot of evidence that iridium does have a benefit and is in fact cheaper - which is amazing to say the least, here is a post and note the contributions from sharif, pretty much anything he says on 350zs is good advice
http://www.my350z.com/forum/showthread.php?t=193978
So Ming, you have indeed replaced like for like :D
Cheers Guys
Allthough the pictures I took do not show it - I am crap with digital cameras - the ones I took out had 'signs of wear'. I agree that they were in good condition and would have lasted many more miles. They were the right colour indicating a healthy engine but they were not as good as the ones I put in.
My point was that the car, being second hand, was of unknown providence and as such it was a precaution. The importer has changed the oil and filter BUT I am going to change them both as well so I KNOW they are right.
Oil should last 8,000 miles but I will change mine in half that.
The same with plugs. i can forget all about them now for my life with the car.
I also have six spare iridium plugs SHOULD I need them! ;)
Ming the Cautious.
Slightly off topic but has any one seen the size of the oil filter. :scare::scare:
Looks like it belongs on a honda 50 moped :teeth:
I have had 1300 cc cars with bigger filters MUCH bigger filters.
Mine gonna get changed OFTEN!!!!!!!!!!!!!!!!!
Ming the now VERY cautious
I think I'm right in saying that the Micra uses the same filter. :scare::)
