350ZGT Posted June 21, 2010 Posted June 21, 2010 Hi All, I have recently bought myself a early 2004 UK GT Coupe and after a couple of weeks of ownership I have a slight issue! It is a manual car and when the clutch pedal is not pressed it makes a funny noise from the front somewhere but when the clutch is pressed in the car sounds 'sweet' no funny noises at all. The clutch on the car was recently replaced so im assuming it wont be that (1000 miles ago). Could there be something wrong with the flywheel? I would appreciate some help please. Thanks Quote
Husky Posted June 21, 2010 Posted June 21, 2010 clutch release bearing, should be able to search it on here Quote
martinmac Posted June 21, 2010 Posted June 21, 2010 Any idea if the clutch is a standard OEM replacement or an uprated one. Quote
350ZGT Posted June 21, 2010 Author Posted June 21, 2010 Any idea if the clutch is a standard OEM replacement or an uprated one. Its definately a standard clutch! Is this problem of release bearings quite common then i assume? Quote
Vik54 Posted June 21, 2010 Posted June 21, 2010 Any idea if the clutch is a standard OEM replacement or an uprated one. I was just going to ask the same...doesn't the Exedy 'chatter' a bit below 2krpm? Quote
Husky Posted June 21, 2010 Posted June 21, 2010 Any idea if the clutch is a standard OEM replacement or an uprated one. I was just going to ask the same...doesn't the Exedy 'chatter' a bit below 2krpm? mine doesnt quiet as a mouse and a beautiful feel to it! EDIT: its the lightweight flywheels that chatter below 2k Quote
Neilp Posted June 21, 2010 Posted June 21, 2010 Clutch rattle is normal. It's the dual mass flywheel. Very common, nothing to worry about. Quote
terribleone Posted June 21, 2010 Posted June 21, 2010 The clutch release bearing is noisy as hell on these cars, everyone I've spoken to with one has the same issue. I've read up on them, people have had them replaced only for the new ones to do the same within a few 1000 miles. Quote
