Simboy1973 Posted June 12, 2010 Posted June 12, 2010 Evening, all. Got the Zed back from Nissan after major service... I'm told the n/s bank of the engine, the rocker cover is leaking oil into plug No 6... Anyone else had this.? The fix - - a new rocker cover will fix it according to the garage... _ Price Please £300 - - i nearly fell over. I've ordered from the web two rocker cover gaksets, they might work.. But at this point in time, gaskets are cheaper than 1 cover.. If it doesn't work, then a new cover it is.. Your experiences. Si GT4 in UY - 124 Quote
ATTAK Z Posted June 12, 2010 Posted June 12, 2010 new gasket won't fix it ..... new rocker cover is the only way as the plug seals are integrated ...... common problem I believe pm Zmanalex .... I think his are cheaper Quote
Vik54 Posted June 12, 2010 Posted June 12, 2010 There was someone just last week had same issue - can't find the post though As Attack says - zmanalex can sort you out witht the rocker cover Edit : It was you! http://www.350z-uk.com/forum/viewtopic.php?f=10&t=34529&p=560978&hilit=rocker+cover#p560978 - so you already know how/where you can sort this issue and you're only down the road too Quote
