How long is to cure/haze? (wax)
Sorry for asking a daft question.
I've had a look at the guides on detailing world, and here, but can't seem to get a definitive answer, time wise.
The reason I ask is because last week I done a snowfoam/rub down/clay/snowfoam/polish/wax. I gave the wax maximum 10 minutes while I worked on the windows, the sun hit the car for a few minutes and when I tried to remove the wax it was solid, like dried plaster, it then proceeded to flake off and covered the car in tiny white dots and I had to strip it all with fairy liquid and start the whole thing again.
Sooo I'm a bit scared to do that again and just wondering if you guys apply wax in one hand, and remove it sharpish with the other, or is it a case of 2-5 minutes?
Thanks in advance.
Depends on what sort of wax you are using mate.
I generally wax a couple of panels say wing and door then go back and remove the wax of the wing then wax the rear arch then remove the wax on the door etc.
the big thing to avoid is direct sunlight, it ruins the whole process. What wax are you using? it should have directions on there, or if you run a search on it on detailing world theres always tips for each wax and polish etc.
What wax are you using bud. :)
I was hoping you wouldn't ask that :blush: It was turtle extreme nano wax, and the reason I bought it was because the modified live meet was the next day and it was too late to get anything else! (desperation) I've since bought a liquid type which I will be trying at the weekend, called Clearkote Carnuba wax, which I've had good success with their polish.
I'm guessing I should really buy some of this expensive stuff that's for sale on the forum, but I can't afford £40 for wax at the moment.
may be a silly question mate but are you using a damp cloth to apply the wax?
it applys the wax easier and rubs in in stead of sitting on the surface
Hi mate, was using a little orange circular foam pad that came with it. Do you find the damp cloth works well?
When using a new wax, always test a panel first. Different waxes take different times to cure, and even the same wax can take different times depending on heat. Also its a lot about preference. Some like to leave it to set really hard and really cloud over, some prefer to leave it less and still be soft. The main thing is to apply it as thinly as possible, and layer it, rather than do one single thick coating.
Give it some more practice (out of the sun) and you'll soon find the happy medium. If you leave it too long, just mist it down with QD and it should come off :thumbs:
That's how your supposed to apply wax with the foam applicator,warming the wax before hand makes it easier to apply.I have never heard of using a damp cloth to apply wax. :scare:
Depends on the wax. A "proper" wax like Dodo needs to be applied via MF or foam pad (dry bar wax). Some of the other brands need to be applied with a damp cloth. Best to follow the manufacturers instructions ;)
