Wheel bearing and control arm causing weird sound
Took it to the dealership and they said i need to replace the wheel bearing and control arm.
they showed me the problem and the oil/gunk was surrounding the wheel bearing and control arm.
do i really need to have the control arm replaced?
does anyone know where i can order these parts?
I can help you with this Dr.T
I have a selection of preowned suspension arms available but I would require confirmation of which one you require.
The bearings in the links below are Genuine Nissan and brand new and are good to go next day.
Alex.
viewtopic.php?f=32&t=28625
viewtopic.php?f=38&t=29441
does anyone know what is connected to the wheel bearing?
does the following connect to the wheel bearing?
OES Genuine Front, Passenger Side, Lower Control Arm for 193 USD
Mate, before you buy any of the bits your looking at I would take Alex's advice... He knows what hes talking about and if you buy the stuff from the US there may be differences... And you need to take into account weight for shipping and tax...
At least you know what your getting from alex :)
The front wheel bearing is part of the hub.
The hub is bolted to the hub carrier with 4 bolts.
The road wheel fits on the hub with 5 lug nuts. :thumbs:
That is the exact same problem i had - although my bush was much worse than that.
I replaced them both with moonface racing roll center adjusters, very good quality parts and should bring my geometry back inline with stock.
Don't know if its any use to you, but i have a new JDM 350z Off side (drivers side) hub carrier with that new bush on it i need to sell..... not needed now i have the moonface racing parts.
