Springs
dan4
have been told that if you lower it you need the camber adjustment front and rear, but i don't know if this is true in every case?
Depends if you want to run camber or not ;)
Mine is lowered 25mm in the rear & I have a bit of neg camber. If my wheels were straight then they would rub against the arches.
i'm sure i remember someone saying some cars need it and others don't, because the zed camber is already close to the limit, and with some cars when you drop them they fall out side of the Zeds adjustment range, and so require a camber adjustment bolt. is that just at the rears, or is it front and rear.
i'm not changing wheels, so wondered if i might get away with it. as i'll be dropped on standard rays. if i do need camber adjust how much is it for front and for rear?
i should hope they are good for over 200quid!
The Teins are over £200 as well.
R
You look in the wrong places.....£160 ;)
You both look in the wrong places, £114 :ninja:
Also try dropping andwood a pm, as he has a set of eibachs that he may be selling
Where on earth did you get them for that price???!?!?! Is there a zed going around somewhere with no springs? :lol:
R
  • 3 weeks later...
Are there any springs that only have a small drop - 15-20mm? I am keeping the Rays and don't want a full 30mm or so drop as I have too many speed bumps etc where I live. Just a subtle drop would be ideal...
+1
and with my soon to be fitted nismo kit, i don't want to be grounding out
