Jammy007 Posted August 15, 2009 Posted August 15, 2009 Just got back from the dealers who've just done my service for me and they also do a health check. Front discs showed up which i'll get sorted & rear drops have slight play but the main one is they said the flywheel is making a noise when the engine is switched off and it should be replaced. Cost is astronomical & obviously if it did need changed I'd go for an aftermarket job. The noise isn't any different from what the cars always done, isn't the flywheel a little noisy any ways? Quote
Greekman Posted August 15, 2009 Posted August 15, 2009 Just got back from the dealers who've just done my service for me and they also do a health check. Front disks showed up which i'll get sorted & rear drops have slight play but the main one is they said the flywheel is making a noise when the engine is switched off and it should be replaced. Cost is astronomical & obviously if it did need changed I'd go for an aftermarket job.The noise isn't any different from what the cars always done, isn't the flywheel a little noisy any ways? When the engine is switched off??? Quote
Jammy007 Posted August 15, 2009 Author Posted August 15, 2009 Is that a joke, i'm stoopid but not that stupid. Only when He meant the noise when the engine is being switched off....... I don't really know on this one but doesn't seem right to me. Quote
Ebized Posted August 15, 2009 Posted August 15, 2009 As you are in Cumbria I am sure one of the locals can help verify the problem - ask Martinmac for starters Quote
ZMANALEX Posted August 15, 2009 Posted August 15, 2009 Just got back from the dealers who've just done my service for me and they also do a health check. Front discs showed up which i'll get sorted & rear drops have slight play but the main one is they said the flywheel is making a noise when the engine is switched off and it should be replaced. Cost is astronomical & obviously if it did need changed I'd go for an aftermarket job.The noise isn't any different from what the cars always done, isn't the flywheel a little noisy any ways? Providing the noise from the oem fly is not to bad then might be an idea to wait until you require a clutch as the gearbox has to come out for both jobs. If you are around 40,000 miles then that time will not be to far away. I have Fidanza flys and Exedy Clutch kits available at great prices. I also have a selection of Brake Discs and pads and have some special offers on at the moment on Performance Friction Rotors and Ferodo DS 2500 pads. OEM ARB drop links are on the shelf as well as the after market adjustable type. All the above are available for next day delivery and if I can help you further then just drop me a pm. Cheers, Alex. Quote
