Hi all, the airbag light is constantly flashing!! I had this re-set with the computer which sorted it for 24 hours only!? On reading the car manual it talkes about servicing a small tseatbelt tension device has well has many other things. Can anyone advise or is it a NIssan task (ouch)
Hi
I had the same problem and it turned out to be the springy thing in behind the steering wheel that needed to be replaced. :headhurt:
It was under warranty but i believe that reading the srs(airbag) codes may be specialist nissan dealer thing :wacko:
Check under the seats to make sure that the loom clips are all connected. You may have had a bottle or something roll around under the seat and cause a disconnect. It may be worth disconneting the battery and then unplugging and plugging in all the connectors.. And then trying the reset.
