rik Posted May 11, 2009 Posted May 11, 2009 Hello to you fine chaps on here! Just womndering i seem to be having a spot of bother with my JDM Z 03, The car has started to run like its missing and will not allow you to accelerate at all. Has anyone come accross this before or can can anyone help me please! Rik Quote
Andy Posted May 11, 2009 Posted May 11, 2009 Is the engine management light on?? You could try the ecu reset procedure and see if that helps. Is in the Guides section. Quote
MITZ@CougarStore Posted May 11, 2009 Posted May 11, 2009 Hi Andy where abouts is the ECU reset proc? Have a look here, Rik... viewtopic.php?f=35&t=89 Quote
3FIDDYZ Posted May 12, 2009 Posted May 12, 2009 Is the engine management light on?? You could try the ecu reset procedure and see if that helps. Is in the Guides section. Your favorite!!! To the OP, did it work and also any mods on your car like hi-flows? Quote
Andy Posted May 12, 2009 Posted May 12, 2009 Is the engine management light on?? You could try the ecu reset procedure and see if that helps. Is in the Guides section. Your favorite!!! I still know it off by heart now! Quote
marzman Posted May 12, 2009 Posted May 12, 2009 Do you have an automatic? Did you lean on the snow mode button with your elbow? The first time i did that i thought my car had died, and i couldn't go over 20mph...! Quote
jim Posted May 12, 2009 Posted May 12, 2009 Do you have an automatic? Did you lean on the snow mode button with your elbow? The first time i did that i thought my car had died, and i couldn't go over 20mph...! +1 Check this first. Quote
rik Posted May 18, 2009 Author Posted May 18, 2009 Magic by reset on the ECU its done the trick, thanks to everyone for helping! Quote
