CaptainSensible Posted April 21, 2009 Posted April 21, 2009 I’ve had my Zed for just over a fortnight now and generally loving it, but there are a couple of questions I have: Firstly, over the last few days with the great weather have been driving around with the windows down. Have noticed that when giving it the beans that I hear a slight whine from the transmission, sounds a little bit like a supercharger if I’m honest, although my car isn’t supercharged! Does anyone else get this or could it indicate a problem? Secondly, the Bluetooth phone kit. Unfortunately the dealer I bought my Z from lost my manual. I have found a PDF of a American manual online but it has no mention of how the Bluetooth system works. It would be pretty handy to get it set up, anyone know where I can find a guide? Thanks. Quote
srobrien Posted April 21, 2009 Posted April 21, 2009 Can't help with the Bluetooth, but I think the whine is a common thing, i get it anyway, don't think its anything to worry about, probably an alternator/grounding issue. R Quote
M350ZB Posted April 21, 2009 Posted April 21, 2009 There is a guide on here bud, use the search feaute, got mine off of here, and tells you exactly everythin gyou need to know Quote
martinmac Posted April 21, 2009 Posted April 21, 2009 I hope this is of some help. Voice command mode is activated by the LH middle switch on the steering wheel (the little face with sound waves coming out of it). On first use you will need to enable it with a PIN number, e.g. for your specific mobile phone or for the Bluetooth adapter. Say "Enter PIN" and when the system replies speak the four numbers of the PIN. Other voice instructions available are then: "Delete" "Delete all" "Repeat" to correct and check your PIN entry. "Dial" and "Redial" "Store name" and then follow the system voice prompts. Repeat "Store" when correct number successfully accepted. You can also use "Delete", "Delete all", "Delete first" and "Delete last" to make corrections. "Repeat" to verify the number entry. "Dial name" lets you recall a stored number by speaking the stored name. "Dial number" allows you voice input the number to be dialled. After speaking the number and hearing confirmation, say "Dial" "Play names" or "Play phone book" or "List phone book" or "Read phone book" will get the system to tell you who is stored. Remove names via "Delete name" and following the system voice prompts. Quote
CaptainSensible Posted April 21, 2009 Author Posted April 21, 2009 Thanks gents, have put my mind at rest. Plus will give the bluetooth a try. I did try to search but obviously not hard enough as couldn't find anything. Driving over to Cardiff tonight for dinner, looking forward to doing a racing start at the bridge toll. Quote
Ian Posted April 21, 2009 Posted April 21, 2009 Bridge toll ftw Its almost worth the £5.40 just to do it Had a little play with an Evo out of there last year but missed 2nd Quote
CaptainSensible Posted April 21, 2009 Author Posted April 21, 2009 Bridge toll ftw Its almost worth the £5.40 just to do it Had a little play with an Evo out of there last year but missed 2nd My brother lives in Chepstow so I get to go over quite a bit. Probably be heading over a bit more now I have the Zed. Quote
